1983 ercoa 21'
- Joined
- Jan 12, 2014
- 632
This motor is on a tri toon I built.
It has a 15 pitch 4 blade and as always ran 5000- 5400 rpm took out one day after idling around it ran up to 5200 and slowly dropped to 3000 rpm so I pulled it to a idle took off same thing. Then it started running fine.
Next time out ran good for awhile then back to 3000 rpm .
Here's what has been tested.
Compression is 100 psi with the exception of one which is 92 well within the 10% allowance.
Spark jumps 3/8 inch.
I had a new stator and timer base I'd been meaning to put on due to some wires on timer base and gouges in the stator from previous owner magnets coming lose. Still 3000 rpm came home put in new plugs ,kitted fuel pumps yes switched to the older v6 duel pumps. checked carbs. Back to the lake improvement 4200 rpm riding around ran out of fuel switch over to back up tank . And noticed the quick connect was leaking just happened to have one with me replace it hoping I had found my gremlin but guess not still 4200. Any ides or thoughts?
