Evinrude E200 TX does not start
valdr
My 93 Evinrude 200 TX (Q02614230) does not start. Over the last weeks / month it was hard to cold start, but once the moter started, it would start again without a problem. However last week end I put the boat in the water, cranked the motor, but it did not start at all. The flywheel turned, the spark plugs were wet, but no actual spark at the plaugs. How do I go about trouble shooting the ignition system? Are there any tricks to disable the kill switch, etc, to just eliminate any wiring problems. <br /><br />Thank you very much.
Joe Reeves
Re: Evinrude E200 TX does not start
Walt.... Remove the spark plugs. Rig up a spark tester whereas you can set a 7/16" gap. Crank the engine and observe the spark. From what you've said, I would assume you have no spark.<br /><br />Now, disconnect the large RED main electrical connector at the engine (plugs still removed). Crank the engine via a jumper from the battery terminal of the solenoid to the solenoid's small 3/8" nut terminal to engage it.<br /><br />If you now have spark, there is either a faulty ignition switch, kill switch, or a short in the instrument cable (engine to control area cable).<br /><br />You can test the ignition switch by re-connecting the RED cable, then remopving the black/yellow wire from the ignition switch. If removing that black/yellow wire results in the return of spark, replace the switch.
valdr
Joe, that helps, and I now have my week end work carved out...<br /><br />Thanks again, Walt
valdr
Pineypowerwpww, I got a little further, but the moter is still not starting. It seems there must be some wrong with the power pack, but I don't really know how to test it. I may just replace it.
yeah Pkswalt i ran into the same problem i have come down to the power pack yoodid u happen to figure out how to test it
valdr
Run out of time and patience and took the boot into a shop. They told me that the stator is damaged, showed me the melted isolator, which dripped down from the coils. Will set me back over $ 300 just on parts. Hopefully get it back this week.
well pskswalt i replaced the powerpack and still had no spark went tested the trigger coil and that was dead shorted so i got a used one that checked out good put it on and now i got spark but from only side i have no clue what the hell do do now..was thinkin that this trigger coil that i got might b the wrong one for my motor dont know tho..
valdr
Had the boat out this weekend and it runs better than ever. The shop said they replaced the stator and reclued some of the magnets. Cost over little $ 540 was well worth it.
