Re: EVINRUDE ETEC MOTORS
Bass Man: <br /><br />I'm the guy with the Alaskan and the e-tec. Actually, it's an 18' foot Alaskan but I don't think that makes a lot of difference. The 50hp gets down to 0.9 consistently. But to do that, the dealer set the RPM down to 600. (You probably already know they can adjust the RPMs quite a bit on these). Also, the prop was selected for trolling...and that affects the top end a little. I get up to 32mph. (boat went a little faster with my previous carbed 2 stroke). <br /><br />Too bad you didn't post this a couple weeks ago. I was in your area fishing and you could have checked out the motor. But the dealer I worked with is closer to you in Decatur, MI. I'm sure they'd be happy to help you out. If you need any further info, let me know. Good luck, Trout
