Re: Evinrude Fastwin: 10 or 18?
I took a rag with a little lacquer thinner and removed most of that black rectangle (the one that looks like a cut-out section) where someone had masked and painted the cowling. Sure enough, the top half of that "18" magically appeared! Thanks, Chinewalker. You are quite the sleuth. Also, I noticed, in the verbage of the the old advertisement you enclosed, a suggestion to opt for an electric-start. Wish I had one. That thing is a beast to crank with a rope!
Thanks for the tips, walserjaw. Yes, it is an "FD". When I first got the rig, several years ago, I called AlumaCraft to see what info might be available. The Gal with whom I spoke was extremely helpful. She had to dig out the old (microfiche) records; and, with the ID number from the cast-aluminum transom braces, informed me that the boat was one of about six-hundred built in 1958. It's a great hull and built like a tank! She even sent along an old advertisement showing it with a covered bow; steering wheel helm; upholstered bench seat; and, a girl on skis in tow. I'd bet this 18HP was the original motor that came with the boat when it was new. She's a wonderful craft, indeed.
