Hi guyz.
Maybe someone on here can help me out by answering this question for me.
I have an old Fastwin my father told me was late 60's early 70's were not sure of the exact yr. Serial #18902B-E04904
This motor has never seen salt water & when you take the cover off looks like a new motor.
It has always ran great & never gave me any trouble.
I put it into gear while the RPM's were to high & striped out the lower end gears that connect to the prop shaft.
Heres the question.
I read somewhere that Johnson & Evinrude back then used the same lower ends on the 15-30 hp motors.
Is this true & are any of the fastwin lower ends compatible or interchangeable.
I need to find a good lower end because durring a move a couple yrs ago I lost the parts after taking it appart, which also included the bottom fin & prop.
Any help with this question would be greatly appriciated.
Thanx.
Heres the question.
Thanx.
