Evinrude Fisherman 6
Roland54
Hello, first post, glad to have found this site, I was given a small outboard, that I like to get going, has not worked in a couple of years, its an Evinrude Fisherman 6. I like to start by finding out what Year it is. the Model# is
6102G-J04609, 1972 maybe? Thank you.
D
DJ
Guest
Re: Evinrude Fisherman 6
Terrific engine. Great runner. Do the following.
1. Check compression. Should be about 60 psi in both lungs. Even is key.
2. If OK, change lower unit lube. Change the fill/drain plug seals for a sure seal.
3. Change the water pump impeller.
The only issues I see (potentially) are ignition coils and points/condenser.
A total of $100.00 could make that engine run another 50 years-easy.
Roland54
Thank you very much Gents! to check compression I need a mechanic right? I was thinking about bringing it to an outboard repair schop, just wanted to know what to say before I get taken .... or not.
bob johnson
dont over tighten the screw that goes into the fuel filter...
I just picked up a minty 1968 6 hp and it had that plastic piece under the screw cracked badly...spewed gas every where...
am now waiting for new gaskets and plastic piece( I have two of those motors )
nice little motors
be vary carefull laying that motor down, or be vary carefull if you stand it up, to keep it from falling over, because the shift handle breaks easily!!!
seems almsot everyone I know has had theirs break...
and the mechanic says it is a very common!!!
good luck
bob
swfl mike
I have a '72 extremely reliable. I agree with the above post my shift handle broke off too.
D
DJ
Guest
You can buy a compression testing kit for under $20.00.
cajuncook1
Just thought I would share this with you.
About a year ago I purchased my first boat and motor. Used but decently kept up aluminum boat and really nicely kept up Evinrude motor. But I found out that bringing it to a mechanic was very expensive!!! To change to lower unit oil, impeller, and parts was about $300.00. It was also very hard to find someone that would work on a older than the mid 1980's. I realized that I could learn how to do that my self and only incur the cost of the parts which was about $60 to $70 dollars.
Over the 1yrs I have learned to rebuild a 1965 9.5hp Evinrude, 1972 2hp Johnson outboard, and 1967 6hp Evinrude.( The guys on this forum are great at giving good sound advice and even supply picture and stuff to help out.)
First thing is to get manual for your motor. The 20 to 30 dollars you spend on a manual will save you hundreds and maybe thousands of dollar by doing it your self and most of all, correctly.
You can find manual here on iboats:
http://forums.iboats.com/showthread.php?t=301361
Ebay:
http://cgi.ebay.com/ebaymotors/1972...8319025QQptZBoatQ5fPartsQ5fAccessoriesQ5fGear
Very informative websites!!
http://forums.iboats.com/showthread.php?t=299680 (tons of good information here)
http://www.sschapterpsa.com/ramblings/OMC_6hp.htm
http://www.sschapterpsa.com/ramblings/o ... l_code.htm (How to identify your year and model motor for Evinrude and Johnson motors)
http://www.sschapterpsa.com/ramblings/O ... 20info.htm
http://shop2.evinrude.com/ext/index.asp ... 317448f722
http://www.duckworksmagazine.com/06/col ... ticles.htm (good article on how to apply a universal kill switch)
Advice on tools and stuff to get started(If you would like to start fixing and maintaining your motor)
-- Tools you need to start out with that won't break the bank
These can be bought at Harbor Freight, Auto Zone, NAPA, Sears and etc (That's if you don't already them)
*hammer
*set of standard wrenches
*standard socket set
*set of screw drivers
*needle nose pliers
*compression tester about $10
*Feeler guage about $6
*Hamonic balancer flywheel remover about $15 (along with 3 #8 harden steel bolts purchased separately)
*torque wrench about $22
*a spark gap tester about $5
*grease gun about $15
Digital camera is useful when taking things apart and remembering how to put it back together. Also, use cheap zip lock bags to organize pieces and label the the bag, so you don't forget parts or lose them.
If you have problems on the way, post a question and you should get some excellent advice.
Good luck!!
Cajuncook1
Roland54
MUcho thanks, I really want to do it myself, I tinkered with some Moped engines and even a Ford 308, I think I can give it a new lease on life, its the ultimate recycling... Cajuncook? you on Tinboats? I am Froggy ( handle was taken here..)
kbait
A spark tester and a flat file for breaker point cleanup and the list of tools is pretty complete.. Oh, and a strapwrinch to fit around flywheel for torqueing it back on.
cajuncook1
What's sssup Froggy? Yes I like to check out Tinboats, they have excellent aluminum boats modifications and restoration projects posted.
Iboats' forum give excellent advice on outboard motor repair.
Cheers,
cajuncook1
Roland54
Well, I got some of the manuals for the Motor, the 71 service manual is great, pictures and everything, Question, the starter pul rope needs replacing, do I need any special rope, or can I use like a lawnmover type rope?
Thanks
Roland54
Finaly got around working on it... , has been sitting for a while. Compression is 62psi and 61 psi good right? changed plugs .30 gap, gas 50: 1, changed gear oil, nothing happen , no spark or cough or anything, checked the gas filter screen clean, looks like gas goes there, I guess I need some kind of start up kit, any opinions and ideas on how to proceed? Thanks
cajuncook1
Just by chance did you turn your tiller grip handle to start or a little past that?
You have to advance the cam to get it to spark and fire up. Sometimes we all forget to twist the tiller handle to start and realize after a couple of rounds of pulling that its not on start. (Not that's ever happen to me.....lol :rolleyes:)
cajuncook1
