Scubaproh20
- Joined
- Aug 30, 2010
- 57
Model 6302Sj Evinrude Fisherman 6Hp
Top cylinder: 105psi, golden brown plug
Bottom cylinder: 93psi, Very black plug
Motor has no spark at either cylinder, probably bad points or condensers will pull flywheel soon. Lower unit is good water pump in unknown condition but no signs the motor was over heated (pistons looked good no cylinder scoring power head paint not blistered) and there is no connecting rod play that is visible or audible.
The motor was really stiff but some tcw3 immediately loosened it.
At this point (no attempt to start yet) the fuel pump diaphragm and ignition are suspect. I feel like the compression may be low but I tested it without fuel/oil available. A carb kit will almost certainly be installed because the motor has been sitting in a shed for almost 25 years
I would like feedback on the compression situation, and confirmation that my suspicion of the fuel pump is on par for the rich looking bottom cylinder
