Hi, I have an Evinrude 90hp 1986 model: E90TLCDC. My problem is this: Motor start when I push the ignition key to prime it, then it will stay running for about 30 seconds and will go off ageing, Now when I push the ignition key to prime the motor, motor will start again and it will go off ageing after 30 seconds but if before the motor go off ageing I push the ignition key to prime it will stay running, so to keep the motor running I have to keep using the ignition key to prime the motor, Like that it can run all day. Does this motor come with a full pump? Please any advise or any Help I will really appreciated.<br />Thank you
