Hi,
I have a 1994 140hp evinrude outboard with some gear problems.
Half way thru the summer I lost reverse. The throttle would just rev the motor when I tried to go in reverse. Now the motor wont engage in drive unless I wiggle the throttle back and forth, and it eventually engages once it is engaged in drive it stays in. No reverse though.
I took the boat out of the water and drained the oil. There were gear shavings in the oil but nothing to significant. I purchased the boat this year and this was the first time I went to change it and it was very milky also.
So I am going to change it and change the seals on the plugs.
Any suggestions on what the problem might be?
Thanks!
Thanks!
