Evinrude/Johnson 110HP, 1994
started motor, heading out slow wake speeds. motor still cool, motor kicks in strong for a period, then just drops back to crapo running, like its on 3 cylinders, then pops up to smooth strong running, then rpm drops down, head shakes more. all at no certain interval. so far all at idle speeds mind you.
got out to bay, goto WOT, motor does not have jump it usually has, but slowly climbs to a plane with a pretty good head shake. (18ft CtrCon, 1/4 tank, just me, no gear). RPM climbs but wont go rpm past 4k. (usually hits 5700)
then...at any undetermined time, BAM...full on power like someone hit a switch, sometime later, motor drops back into sluggo mode through all rpms, just like when it did at no-wake speeds.
I disconnected the temp sensors did another run with same results. keep in mind that the on then off power seems completely random.
Drivin me nutz.
Things I observed:
all 4 spark wires are firing (timing light check on each wire)
good charge while running (14V)
did a static advance test. 24BTDC. ok.
spark plugs are Champion as defined in manual and 2 weeks old.
visual check on water via pee stream. ok.
both carbs were taken off and cleaned in April. (just maintenance)
about the only thing i have not replaced is the power pack and i dont know if theres a reliable test for that, but i'm about to replace it by default.
I've got the motor up on davits ATM, so i'll test out any ideas you come up with.
thanks
Drivin me nutz.
Things I observed:
thanks
