slabhunter
- Joined
- Feb 23, 2005
- 22
I have a 1972 50hp Evinrude that just won't start. With the plugs out it cranks fine but put them in even loosly and it barely cranks over. Have cleaned all connections, tried a new starter, tried a new 730 CCA battery and no difference. Have tried both through the solenoid and direct to starter and no difference there either. The motor has good compression, incredibly good spark, and fuel to carb. It simply won't crank fast enough to start. It's the electric shift type that needs to build pressure before going into nuetral but from what I've seen on the forum (and common sense that they wouldn't have sold many) I doubt that would cause this. I'm no marine mechanic but I've fixed a lot of motors and I'm stumped here. One point: I don't have the external wiring harness or controls. But with compression, spark, fuel and going direct to starter I'd think it should still run. Sorry for the long post, just figured we'd save time if I give more info to start with. Any help appreciated.
