Re: Evinrude help!!
Have you checked all connections and proved the primer bulb all the way back to the tank is tight? Also, when you start the engine does she fire up and stay running or do you have to keep priming?
I suspect air is getting in somehwere, usualy once you prime, provided your lines are tight, she shouldnt lose prime...
check all your hoses and connectors (is you have any)...mine is direct to my engine with clamps and not the quick connects..
