NealLauderman
- Joined
- Feb 12, 2007
- 191
I like doing things on my own and typically don't give up easy. However, I am pulling my hair out! I bought a 1997 Evinrude 25hp (e25reum) from a buddy and it hadn't been run in a year. My buddy said it ran rough the last time he had it out and started barely peeing.
First thing I did when I bought it was:
1- Replace the spark plugs.
2- Replaced the lower unit oil. (It was in good shape and not milky)
3- Replaced the water pump. The water pump was in rough shape...
I put it back together and was impressed when it fired up on the second pull and ran like a champ. A little rough but not bad besides smoking like a 2 stroke bandit. Anyways, what brought me looking for help is that for the life of me... I cannot get it to PEE!
The first time I started it on muffs. I figured maybe it just needed to be in a tank. That was a no go and produced the same results. I dropped the lower again and checked the waterpump to make sure I wasn't burning it up. It was in good shape and was obviously getting water.
I checked the pee hose coming off the engine and it was clogged with some kind of dirt. Got it out and put it back together thinking I fixed the issue. It still didn't pee on muffs or in a tank. I dropped the lower AGAIN and checked the water pump. It was in good shape still. I took my compressor and put the copper water pipe where it goes in the motor shaft and blew air through the system. (This was recommended by and Evinrude mechanic) I could feel the air coming out of the pee hole so there wasn't a clog. Putting the lower back on I shot the plastic "keeper" into my yard and lost it. Ended up having to order a new one! I just received that and put everything back together and it is still not peeing on the muffs or in a tank.
I am at a loss... Please help
Here is a link to a video I took showing the issue:
https://www.youtube.com/watch?v=ijjZRI2BHOs
