Re: Evinrude/johnson lower unit measurements
Measure the length of the driveshaft from the top to the lower unit mating surface (with midsection). If in the range of 27" it is a 25" gearcase. If in the range of 22", then it is a 20" gearcase. Doesn't matter exact numbers....there is a 5" difference, so to determine which one you have, you gotta just know the ballpark.
If you have the wrong one for your motor, it is a real task to swap the driveshafts, by the way.
