mikehoustontx
- Joined
- Apr 4, 2004
- 13
Im having a lack of power issue with the top cylinder on a 1984 Evinrude 50HP 2 cycle 2cyl. outboard Model E50TLCRM.. The powerhead has about 30 hours on a complete rebuild.. Before the problem occurred the motor was running fine. It sputtered briefly due to a low fuel level in 1 of the 6 gal tanks. I switched to the 2nd tank and continued fishing with no problems.<br /><br />The last trip to the lake, the motor started but idled a little rough. Away from the dock, it would not accelerate; no power. I loaded it up and brought it home to troubleshoot the problem. Throughout the troubleshooting, the problem has remained with the #1 cyl. A compression check on both cylinders shows 150 psi with no discernable variation. Occasionally, fuel will spit out of the #1 carb as the motor jerks.<br /><br />A list of things checked so far.<br /><br />A. Electrical<br />1. Swapped spark plugs<br />2. swapped plug wires<br />3. swapped coils (wiring was modified so that power pack would fire correct coil)<br />4. checked spark to ground (3/8 inch plus spark, both cyls.)<br />5. connected timing light; good steady spark on both cyls. At idle, #1 firing at TDC, #2 at 180 degrees from TDC<br />6. Checked battery voltage; 12+ volts<br />7. Inspect and reseat connectors<br /><br />B. Mechanical<br />1. Disassemble, clean, and check carbs, matched float levels<br />2. swapped carbs<br />3. swapped V-box reed plate assemblies<br />4. Installed new fuel pump kit<br />5. Temporarily installed clear fuel line tubing to upper carb; good flow with very few air bubbles<br />6. Squit fuel directly into upper carb (at idle)<br />7. Inspect upper crankcase seal; packed around seal with petroleum jelly, ran motor, then reinspect seal for signs of a vacuum leak or blow by<br />8. Checked stator for possible rubbing on flywheel.<br />9. Carb air flow test; by holding a piece of paper 1 inch or so in front of the carbs, a fine mist of fuel was visible on the paper. Covering the carb with paper; on #2 cyl a puddle of fuel would develop at the carb opening and the motor dies, #1 cyl a fuel puddle developed but the motor would continue to run.<br />10. KICKED it and CUSSED repeatedly.<br /><br />Any ideas??? <br />Thanks in advance<br />Mikehoustontx
