Folks I just got a 40 HP Lark. It is mounted on a 1964 Starcraft 16 ft and I have a few questions.
I was told by the previous owner and the local Evinrude dealer that the oil ratio is 50:1. I see the manual calls for 24:1.
What is right? or is the modern fuel and oils just better?
The boat does not get up on a plane it creeps along at about 12-15 mph at full throttle from the helm? I am hoping it just needs a throttle adjustment. Would this be done from the shift box or on the engine? Engine does not sound like it is at max rpm 4500-5500 rpm. It has good compression with the hand pull start.
How do I adjust trim once I can this engine quirk ironed out?
Also engine has a rough idle and does not idle with the throttle at its stop.
