Eyeballsdeep
- Joined
- Jul 28, 2012
- 63
My buddy had this motor sitting in his parents garage for 8 years. he said it was running when it was put away. i checked compression the top cyl=90psi
and the bottom
cyl=90psi
There isn't a telltail pee hole on this thing! There's water coming out the exhaust holes. But id be scared to run it, scince i always keep an eye out on the pee hole. The head also has discolouration around the spark plugs and after running its quite hot. How much water is supposed to come out of the exhaust? At least with a telltail you can tell how the pumps working. It runs great! It fired right up. All I have to do is spin the flywheel by hand and it starts right up.
and the bottom
cyl=90psi
