Re: Evinrude lower unit (1979 vs 1984)
Hi, My quick answer is NO. They are not the same. I have not taken the time to see if even the year difference matters, but, the 25 inches is made up in two areas. 1. The mid-section is longer. 2. The lower unit has a longer driveshaft and the shift shaft While the shift shaft is easy to swap, the driveshaft requires disassembly of the lower unit to change it.
