evinrude lower unit replacement
t.martin
1989 40hp. I am replacing my lower unit with a new one. I was just wondering if anyone had any tips and pointers on installing it right.
alden135
Re: evinrude lower unit replacement
Tips:<br /><br />1. Buy a manual as you'll need one at some point anyway.<br />2. Replace the water pump.<br />3. If the bolts don't come loose with moderate force, apply heat to the unit before you break a bolt off.<br />4.Check your shift rod height before installing the gear case per the manual specs. <br />5. Purchase a six pack of your favorite beverage and go slow. The pros here can do one of these in 15 min. but I'm no pro.
REELSPORT
all the above is true but when putting the lower unit back on pay special attention to the tubes that tranport the water up to the engine and get them connected properly. good luck
t.martin
thanks for the replys. I have already changed the water pump. I have a book. My biggest concern is lineing up the water tubes.
