gam101
- Joined
- Jun 3, 2012
- 79
Greetings fellow sailors!
Off the bat; newbie ALERT! :facepalm:
Need your help/advice please with the following;
A little history: outboard over-heated one day while I was out, and the boat mechanic said the impeller had failed. :blue:
He;
1) Replaced the impeller
2) Replaced the fried powerpack
3) Cleaned the heads and replaced the piston o-rings (apparently the previous owner had used silicone inside the heads)
4) Re-did all six carbs with carb rebuild kits. because it was idling rough.
I took the boat out & it was slow. It would not go fast period, and when I tried to speed-up a little, the outboard would rattle & shake the entire boat. I mentioned this to the mechanic, and he took it out for a test ride.
His diagnosis; the heat sensor could be faulty & sending an overheat message. He said he disconnected the sensor & the boat was a Mako shark again.
He also said he is not sure if the sensor is bad & that I should just watch the tell-tale flow to make sure the water flow is ok.
I am thinking I should replace the sensor & install a temp. gauge.
My questions please;
1) Would it make sense to replace the heat sensor?
2) Would it make sense to install a temp gauge?
3) If 2 above is "yes", is it even possible to install a gauge on my ancient '98 Evinrude?
Many thanks gentlemen & sailors.
He;
