jstephens85631
- Joined
- Apr 5, 2005
- 8
Help!!!!!!!!!!!!!!Have 1971 9.5hp evinrude i have been working on.finished ignition tune up.Working on carb now.When i started motor carb is pumping to much fuel,flooded motor to the point of fuel fouling plugs.I took carb apart to clean and check jets like the manual called for.Float does not have a spring per manual,Also high speed orifice has been damaged i dont know if i can remove.WHERE Can i get spring and lower float bowl if i cannot remove orifice.i really need some help motor is kiking my butt
