Re: Evinrude overheating
I live in CT and work during the week in NH, so I can't check the repair slip to get the brand until the weekend.<br />Yes, opened the water jackets. There is a gasket that separates the water jacket into two chambers: one on the engine side, one on the cover side. The engine side was fairly clear. The cover side was almost solid with salt. <br />Thermostats are still out, and pressure relief valves are in place. Assume they're functioning.<br />Removed thermostat covers at one point to check water flow (originally thought one side might be plugged). Water flowed out both sides. Question -- how much water should flow? Should it gush? Should it be under pressure? It was a steady trickle, but I have nothing to compare it against.<br />In answer to the question about how hot the engine got: used a surface pyrometer (again, originally looking for a difference between left and right sides) and the outside surface of the water jackets got up to 145-150 degrees F. Before cleaning out the salt deposits, the temperature gauge wasn't reading that hot even when the alarm was sounding. After cleaning out the salt, the temperature gauge was in the red. So the sensor for the gauge is in the outer water jacket, while the sensors for the horn go deeper into the heads.<br />Also, besides running with the hose, removed the prop and put the lower unit into a barrel filled with water to see if it would pump on its own. It did. Ran OK (didn't overheat) for half an hour.<br />Only seems to happen under load.<br />When running on the hose, I tried to look for places where water might be leaking. There is what looks like a tube going up the very front part of the lower unit. Water was running down around this tube. Is there a connection that might be leaking before the water ever gets to the engine? Or is this just spray from the "ears".<br />The mechanic reminds me it was overheating before he replaced the water pump, and he didn't think the pump was the problem in the first place.<br /><br />Laurie<br />I THINK I have now included every piece of useful information. <br /><br />Laurie
