Re: Evinrude peice of crap
The problem is pointed out in all that you just wrote.<br /><br />Seems that you are not sure what an impeler(rubber thing) looks like. Than you say that you took it apart and 'cleaned it right up'. But then you ask if there is a diagram somewhere for this. This tells me you took it apart not quite knowing what you were doing or what to look for or fix.<br /><br />Now you say that it was running and it just stops after getting very, very hot.<br /><br />Now your recoil is broke and you can't start it.<br /><br />WELL, this simply tells me that you have probably seized up something in the motor or the lower unit. Or both!<br /><br />These old Evinrudes are GREAT motors that just keep on going. Calling it a piece of crap only tells me that you did not do the research needed before the work began.
