evinrude question, blowing fuses--Help!
Dave Shipos
I have a 1980 Evinrude 85hp v-4 ---Yesterday I had to put in a new ign. switch--The switch seems to be working, however The problem I am having is that The 20 amp fuse keeps blowing when I try to start it, the motor starts cranking then it stops, "hence the blown fuse"--I do not know if the problem is related to me installing the new switch and by maybe having the wires hooked up wrong--Can anyone tell me if that is possible?--If so, can you tell me which wires go where on the switch? --Thanks so much for your help!--Dave Shipos
Dave Shipos
Re: evinrude question, blowing fuses--Help!
I thought so too, and I thought that I was careful installing it too!--I will recheck it now that I have your diagram--Thank you so much!---Dave
goonski
I had the same exact problem on my 84 johnson 90 hp vro, there was a bare wire in the control box. There was a wire wore through where the bolts go through the box to mount to the boat on the inside of the box, repaired and no more blown fuses!
Dave Shipos
Thanks Cadet, I will look and see if there are any--Dave
Dave Shipos
Its all fixed! Thanks Guys for all your help!--This forum is tops!--Dave Shipos
