Re: evinrude rebuild
Thanks Dhadley,<br />I have been reading the forums untill I am cross-sided. <br />What should the compression be on the 60hp?<br /><br />The #3 had 90, I'm thinking of boring all cyc.<br />The machine shop said that .020 would not clean it up on the other 2, had to go to.030<br /><br />I'm going to rebuild the carbs also, new water pump, thermostat, and anythink else.<br /><br />The upgrade on the cooling also. I am not sure, but is the upgrade the hose on the pisser. If it is mine is on the lower side to the front of the motor on the cooling plate.( T style fitting )<br /><br />I found some bulletin #'s on this on a 1990 model on this forum. Would they be the same for the 1993?
