Even if the model number did indicate a specific shaft length, the only way to be sure would be to actually measure it. Never know if it was changed from one length to the other without measuring.
even if it is 15/20 inch shaft, on a pontoon you are better off with a 25inch, aspeople tend to sit up front , and thaty motor is not strong enough to keep the nose up with all that weight, so you tend to ventilate
