edd_barker
- Joined
- Sep 8, 2009
- 22
Hi all,
I'm new to the forum and to outboard motors, having bought my Evinrude for ?1 last year. She runs like a dream, but when I checked the lower gear unit oil today ( I changed it last month), a fair amount of water (about 10% of the oil that came after) ran out of the drain plug before the oil came out, which even I can tell is a BAD THING.
When the oil came it looked in pretty good condition, and I can't see any oil leaking out of seals, joints etc when the motor is off the boat. Neither of the drain/fill plugs had any sort of washer or seal in them, so I was going to put some rubber O-rings in there, but I wanted to ask if it was likely that the water had managed to get in just through those two plugs, or do I need to replace all the LGU seals with the kit available on iboats? Pretty nervous about this as I've never taken an outboard to bits before and she is my pride and joy.
Will I be ok for what remains of the British summer if I drain the water each time and put more oil in the top? That'll probably be 10-20 hours running time tops.
Many thanks, Edd
Many thanks, Edd
