I have a 1979 35hp evinrude. I was having issues with it dying at idle and not wanting to run full throttle. I friend of my rebuilt the carb and did a cam adjustment as well as some linkage adjustments. took it out yesterday for the first time and the idle issue is solved, however the throttle issue isnt. What happens is when I move the lever to full throttle it only appears to be running half throttle. Sometimes you will hear the engine sputter a few times and then it will run full throttle for awhile and then suddenly goes back to half throttle. I am not mechanically inclined so is there anything I can check before sending it back for repairs? thanks for looking!!
