The motor was up on the travel bar and I thought it was supported by the tilt hydraulic. I lifted the motor up slightly and took it off the travel bar. Bad news - the motor just came down gently and stopped at the bottom. <br /><br />The electrics weren't working at the time so had no way of getting the motor back to the up position. <br /><br />I released the side screw slightly so the motor could be raised back to the travel bar and this worked fine with no loss of fluid. Once up, I tightened the screw.<br /><br />The electrics are now working - the tilt motor is running, but nothing is happening in terms of motor going down with the down switch. I again took the motor off the travel bar and it dropped gently down but only half way this time. I can hear the tilt motor working but again - the boat motor is going neither up nor down.<br /><br />Nowwwww - what do I do????
