Evinrude to Mercury Steering conversion?
H2ofria
I am considering replacing my 1996 28 Evinrude with a 2005 60 Mercury ELPTO. The boat is a 16 Pro-Alaskan, aluminum.
My current steering system consists of a single cable with a stainless rod that passes through a housing in the front of the motor bracket which then connects with a swing rod that attaches to the front of the motor.
Can I expect to be able to use the same system on the Mercury? If not what are the things I should watch out for?
DRIFTER_016
Re: Evinrude to Mercury Steering conversion?
Should bolt right up, you will probably need to purchase the proper "swing rod" from Mercury though. The cable should fit right in the tilt tube.
tashasdaddy
plug and play except for the cable/motor connecting are you need one for your mercury.
Kev144
Agree with TD. Though i more prefer a dual cable system :D
H2ofria
Thanks for the replys. I haven't decided on whether or not to make the change. There is a lot of money involved and I am a simple poor retiree with a kid still in college. I might have to wait until the 96 dies.
tashasdaddy
i understand your pain. mine are finally out of college.
