D
DJ
Guest
Hello Everyone,<br /><br />I took the project boat out again today. I ran into a little problem, that just developed.<br /><br />The engine is a 1983 Evinrude V-4 crossflow 90 hp. (E90ELTCE)<br /><br />The issue is the engine would not reach full (before achieved) rpm of 5400. Top rpm today was 4500. In addition the engine surged while getting up on plane.<br /><br />In my mind, that says fuel starvation.<br /><br />Here is what I did.<br /><br />1. Switched tanks and hoses-same.<br /><br />2. Made sure primer bulb remained hard-it did in both instances. Hitting the primer didn't seem to help.<br /><br />This engine has had both carbs rebuilt-by me.<br /><br />I did notice that the right, from rear, cylinder bank seemed to be running lean. This was determined by examining the spark plugs. Compared to the left bank, the right was noticeably drier.<br /><br />The engine idled fine and ran great up until about 3600 rpm, then the surging started.<br /><br />My question is: how does the fuel/air mixture flow through a crossflow? The manual is of no help. Does one carb. feed one bank of cylinders and the other the other bank?<br /><br />Am I looking at a carb. problem (which one) or a possible reed plate problem? <br /><br />By the way, the only things I have changed since the last outing were the spark plugs (Champion L77J4) and the rectifier.<br /><br />Any ideas?
