I have read on this forum about the casting seam water leak into the no. 1 cylinder inherit in the Evinrude and Johnson 150 HP 60 degree V6 motors. I suspect my 92 Evinrude 150 may have this problem. The no. 1 plug and top of piston are clean compared to the other 5, although compression on all cylinders are in the 105-110 psi range. What year motors are affected? Does the welding of this seam hold up? Any way to confirm leak other than complete tear down?
