Re: Evinrude What year and how to disconnect shift rod
bprewett,<br />Welcome to the forum.<br />Motor is a 1975.
Evinrude <br />Need to find out why it overheated and why your alarm did not function. You may have done some damage to your motor if it ran that hot.<br />There are numerous tests you can perform to determine this however I would suggest you obtain a manual before attempting to troubleshoot your motor. Try a library or you can order 1 from the link at the top and bottom of this website.
Manuals <br />The manual will explain how to disconnect shifter. Some motors are disconnected inside the cowling, while others have an access panel in the side of the case.<br />Post back and let us know how we can help but a manual is a neccessity.
