Evinrude will not idle
samtech
HAVE A 1989 EVINRUDE 150xp. ENGINE DOES FINE WITH FULL THROTTLE, BUT IT WILL NOT IDLE CORRECTLY.
Re: Evinrude will not idle
Not much information was posted on what happened here.--------So I would start with a compression test.
hall832
Fuel, idle circuit has restriction in the carbs.
boobie
As said above, start with the compression test and then you know what you have to work with.
