Re: Evinrude wont start
Hi, when I move the red lever clockwise as far as it will go. I try to Start the motor and It wont start, I then move the lever to where it goes and I push the key in to start and it will start fast, but then will go off fast, (on my control I have a lever that will go up and Down if I leave that lever in the down position the motor will never start, even if I used the prime solenoid, if I bring the lever up half-way it will start if I used the prime solenoid but will go off fast, then I try it ageing with the lever all the way up without using the prime solenoid and it will start but I have to play with the lever up and down until the motor stay running by itself. After that motor will run all day without any problems, I usually go fishing for about 5 to 6 hours and the motor start really fast with the prime solenoid. It usually takes 5 to 15 minutes to start the boat on the ramp. People get really upset at me on the ramp; it is a really busy ramp. Some one told me on the Ramp that the carb are getting to much fuel and that is way it take to long to start the motor but I dont know <br />Thank you
