Evinrude wont idle?
2mate
My 1998 evinrude 25 be25elece has a problem. The choke solenoid has to be set between run and prime in order for the engine to work but the second the revs drop it dies. The engine is fine at high rpm i dont know if this is a faulty solenoid or just adjustment?
Where should the choke be set? In the "run" position in the manual this shows that no fuel can access the little pipes coming from it?
Im confused :S
