Re: evinrude won't start
Paul and others will be along soon, as as they know alot about these older engines. But, in the meanwhile, check for spark first and then remove and clean the carb out. Make sure you are using the correct oil mix (24:1) or 1 quart of modern TC-W3 oil per 6 Gallons of gas.(about 5.5 ounces per gallon). You will also need to check the points, which are located under the flywheel. Point setting is .020. We can worry about that later if you get no spark. Also, the ignition coils on those wer known to crack and cause the no spark condition. But for now, I would put a spoonfull or so of straight TC-W3 oil in the sparkplug holes and replace the plugs. Turn it over about 10 pulls to lubricate the cylinder walls and rings before you get her going. Then if you have spark, mix up some pre-mix at 24:1 in a spray bottle and shoot a little in the carb throat and see if it fires If so, the carb is clogged and needs to be cleaned. When they sit that long, the remaining fuel in the carb turns to varnish... Best I can do for now...<br /><br />Oh, yeah. Do you have a Model number for us? Sure helps..
