Ok. I have been running a thread with Daviet and Levi_tsk helping me for a while now, but I feel I need to open a new thread for this one.
I have a 1975 Evinrude Hustler 75 HP. Now, she starts and idles ok, will shift and run in gear OK. However, when I open the throttle the motor climbs slowly to higher RPMs but it revs up and slows down in RPMs as it climbs. It peaks, but not at optimum WOT, and then it does the rev up/recede in RPMs again.
Now, I have changed the prop to a 15" pitch. And it helped.....A little, but the motor is still not running right. I am going to check the spark gap tester, but I am sure it will pass just fine. Fuel is good, have basically rebuilt it from the ground up.
My question is could it be exhaust. When I run it in the tank, there is an awwful lot of "soot" and it seems to be......inhibited. If it is exhaust, am I damaging the engine running it like that, and how hard is it to open the manifold and check for blockage/buildup. Are there flapper valves that could be stuck open? What kind of parts will I need? I have heard about exhaust could be the problem in a scenarion like this. Please help.
