Good friend just dropped of an evinrude 18hp.... Not sure what it is. Looks just like my qd-19 other then the power head. So he said the motor was working fine going full speed. Got to fishing spot. Fished for awhile. Fired motor up. Put it in F the boat would only go 4mph. Stopped the engine nothing in the prop. Start it up put on R only went about 1mph. Did it a few times nothing changed. Card works good because in N he can run it and super high rmps. But not F or R. Dropped lower unit and gear case. Gears are great shape. And the only thing I can see that's worn is the lowest part of the drive shaft with the part that goes into the gears.... To me it should work. Plugs wires good. Condensers good points/ coils are new. Getting spark. It's like it's not shifting all the way. Plz help. I told he should rebuild the lower unit. Oil mixing with water a good amount of it. That was after he drained it looking for metal. Then put new oil in.
Hope this all makes sense thanks!!
