Re: evinrude
deltaboy <br />have you done the sync and link on it? if not it need to be checked. the low speed jets set at 1.5 turns out, the high speed jets at 3/8 turn out. this is a good sterting point. set points at .020 with someone you trust with your life, on the water set the low speed jets to best idle, at WOT set high speed jets for best high end, I find the you then need to reset the low speed jets again. Evinrude recomends that you use WOT to get on plane the back out to 3/4 throtle to run. About 3 or 4 mph less than WOT, but when you do the sync and link, you'll see that the carb starts to open at 3/4 throtle! If you do not have and cannot find a manual I can post some pages for you to download.<br />Richard
