Evironmentally friendly mixing oils
cobra 3.0
Does anybody use these environmentally friendly mixing oils in their two strokes? (n I believe Shell makes it and it is called Nautilus) What's the experience with these? Is there less smoke or smell or what?<br /><br />The price is quite hefty compared to regular mixing oils and I just haven't had the courage to spend $10.00 Cdn. for a liter(about a quart) of oil to try it out yet.
bossee
Re: Evironmentally friendly mixing oils
They are "biodegradable" and that is one of the main arguments to use these oils.<br /><br />I used for 3 years biodegradable 2-stroke oil in my Suzuki DT65 (1991) without any problem. Less smell - maybe, hard to say. Less smoke - no I did not notice that.<br />The biodegradable 2-stroke outboard oil I used is sold by a gas company that is only in my country. It is more expensive than regular 2-stroke oil but since I maybe used that outboard 50 hours each year it is not that much cost to try to help polute less. I use a 4-stroke now instead (Yamaha F115).<br />I do not know if it is available in your country but in my country You can also buy "akrylat" gas that is very environment friendly considering it is "gas" to use with for example an 2-stroke outboard (I did not use this gas). <br />If You combine the oil and gas mentioned above it is probably the best You can do for the environment with an older 2-stroke today I think.<br /><br />Other biodegradable 2-stroke oil I know of (in my country):<br />Castrol Biolube 100<br />Mobil 1 Outboard<br />Quaker State Synquest Outboard & Snowmobile<br />Valvoline Syn Power Outboard 2T<br />Cargo Poly-Twin
seahorse5
Both Bombardier and Mercury sell a biodegradable synthetic oil and have for quite a few years. They are more popular in European areas that have strict environmental regulations.
