Have a new to me '85 Evinrude 15 hp. Friday, before the purchase, the owner and I put it on my boat and ran it. Ran great. He kept his gas tank. today, I hooked my metal tank up, it started second pull, idled nice but when I opened it up it just would not rev out. Gets to about half, and just won't pick up speed. When I rolled the throttle off, it died, but started first pull.
Idles great takes off nice, but just flattens out. I'm thinking my fuel supply line is to blame. No apparent leaks, but I had to bend the tab where the line connects to the motor to get it to latch on. It does have clamps at the fuel bulb, gas filter, and at each connector. I check the screen at the fuel pump, it was clean. I also siphoned some gas out of the bottom of the tank to check it, no debris. It also has a trolling plate on it. No means to lift and latch it, uses spring pressure, and the prop wash to lift it.
I'm going to try the tank I tested it with tomorrow and see if that makes a difference.
What do you all suggest?
Thank you in advance
