Hello,<br /><br />I have a 1983 Johnson Sailmaster 7.5. Just finished an impeller and lower unit oil change. Put her in the test tank and I'm getting some steam out of the idle exhaust port. Motor seems to be peeing fine. I am also getting exhaust coming out of the area where the shift lever exits the housing. Is that normal? More noticable right after startup. When I put the boat up for the season in November it wouldn't pee at all. The impeller still had all its blades although 2 were cracked pretty badly. Steamed then too.<br /><br />I dont have any way of measuring but how hot should the area where the plugs screw in get? I guess they are the cylinder heads. I pulled the cover off while running and inadvertantly splashed a little water on them and it boiled off right away. Is that normal or is the motor getting too hot? <br /><br />Motor runs and idles well. No problems with it stalling out or bogging like its too hot. <br /><br />Motor is freshwater only<br />Any help and comments always appreciated.<br /><br />Jim
