DamnitBadger
- Joined
- Feb 21, 2005
- 41
1978 260 Mercruiser. While trying to find why my oil had water in it I found the source to be water passing by the exaust plate that is between two gaskets where the elbow meets the manifold. I noticed there were black water marks on the inside of the plate between the water jacket and the exaust (there is a good 1/4' of material here and little if any corrosion). I have purchased new gaskets and plates but was told by the parts guy not to use any kind of sealant, just tork it down. Seems to me that this would be an ideal place for a hard setting permatex gasket sealant. What do the pros do? I'm replacing the studs as well as sanding the mating surfaces.
