JSGOLD
- Joined
- Sep 22, 2009
- 609
I started my 1976 Evinrude 55hp motor this evening after rebuilding the carbs. I know it needs some adjustments but I noticed two things that may or may not be a big deal. When I pressurized the system there were no leaks..NONE. I started it and seems to be smoother but it is a little quirky at idle, as I am sure the low speed jets will need adjusting a bit. There is some excess fuel in the lower carb in the throat...so that worries me a bit. A drop or two came out onto the air silencer from vibration, but it is not pouring out. I did re adjust the new float on this carb a bit to get it to the correct distance, so perhaps something is not right there...or maybe it is just out of whack too much on idle jets??? The other thing is I notice some moisture in the bowl gasket. Not leaking but is it normal for bowl gasket to absorb fuel? Perhaps I overtightened or is that no big deal??
