Excessive smoke '85 150 Evinrude
sabbett4
I started up my '85 150 for the first time this year with the muffs on it. Everything seemed fine for about a minute, then I noticed excessive smoke coming from the right side of the mid-section. I felt the thermostats (which I replaced a year ago) and the right one felt VERY hot (almost burning), the left one felt normal. I felt the mid-section and it was very hot. When I first started it, I felt the stream, and it felt normal (a little warm). When I noticed the smoke, I felt the stream again and it was cool. The stream was good and steady. I understand that it's going to smoke, but the very hot thermostat and the cool stream is causing some concern. Am I over reacting? Thanks
R.Johnson
Re: Excessive smoke '85 150 Evinrude
If it was way to hot to touch, I would replace the thermostat. At least check the seal.
emdsapmgr
Check the nylon pressure relief valve for heat deformation. You may need to replace it also.
sabbett4
Thanks for the advice...I'll start there
