Exhaust Bellow
dc7432
We have a 2000 4.3 Volvo penta with a SX drive. I have a small cut on the side of my exhaust bellow and looking for advice if I need to replace. The stock bellow has small pin holes on the bottom of the bellow that I assume is for water to drain when out of the water. Thanks
dc7432
You should be good. Exhaust bellows are not a critical as drive bellows.
Thanks. Curious what stops the water from entering the bellows / exhaust system as it sits at the dock through the factory holes in the bellows thanks again.
Lou C
Nothing does. That entire system of the transom mount exhaust housing and the exhaust Y pipe are full of water up to a level about even with the bottom edge of the exhaust manifolds when the boat is in the water. This is called static water line. Also why some engines suffer water ingestion and need taller risers to get the exhaust elbows high enough to prevent that.
When you pull the boat out most of that water drains via the holes in the exhaust bellows but not all of it (bottom of the exhaust housing is lower than the exhaust bellows). The exhaust manifolds remain full of water which is why they must be drained during winterization.
