exhaust bellows ripped
DareDog
month ago pulled the boat out put all new bellows in it then put it back in the barn, today took it out going to use to this weekend just checked the back of boat and exhaust bellows were ripped and it just has been sitting! :( is it possible to replace them with out pull the out drive off? 93 bayliner with alpha one.
Fordiesel69
Re: exhaust bellows ripped
Yes it is.....
However, you need to reconsider becuase where you bought the bellows, they may have been old and dry rotted before you even installed them. New bellows doesn't mean fresh!
90stingray
Next time store her with the drive down. But it would be ok to use until you get to fixing it. Were they quicksilver/merc bellows?
joncrisler
What is the condition of the j-joint bellows ? That is the key- you dont want water getting in there. Supposedly there are some rodents and muskrats that like to chew on bellows rubber, so check yours for small teethmarks
04fxdwgi
Mice, maybe? Those little suckers will chew anything that isn't hard enough to break thier teeth. See if it is chewed or split along the convelutions. Never seen one split that quick. It's OK to run that split or with holes in it. It's a fairly easy task to replace with the drive tilted up, on the Alpha. Just take your time and don't get frustrated. The one on my Bravo isn't even connected on the drive side....... Called an exhuast "tube". Some of the kits supply bellows and tube so you can use either one if you want
DareDog
there is no mice, going to call place got them and see if can get new one.
timfives
You can fix it. But keep an eye on the other ones, mine did the same thing. The other ones seem to be 100 %. The marina said this is not an uncommon problem. You can run with out the exhaust bellow it is just going to be a little bit louder than normal.
T
DareDog
how are the exhaust bellows you can buy from on here? they look way different than one that's in there now.
skargo
Banned
Don't some exhaust bellows have holes in them from the start?
They won't make your boat sink...
