thundercat 9
- Joined
- Oct 8, 2007
- 68
Hey Guys'
I just put my 350 merc motor back in the boat(after replacing the starboard head) and was doing some testing just to make sure that it ran cool. I checked the flow diagrams and all my hoses are on right.
I pulled off the hose between the T-stat housing and the riser...should there be any kind of pressure coming out of the riser when the motor is idling? I don't want to get out on the water and overheat... I am doing my testing with the outdrive submerged in a plastic 45 gallon drum laid on it's side(the water inlet is under water).
What is the purpose of the plastic balls(check valve) located in the t-stat housing? Should water be coming out there?
I am getting sporatic readings on my temp gauges.
Any info would be greatly appreciated.
thanks
jeff
thanks
jeff
