workaholic
- Joined
- Nov 26, 2008
- 101
Hi again gang!
Continuing my 283 to 350 swap I am looking for some more pointers. I changed from having the old log style manifolds to center rise manifolds. Thermostat housing that was on my 283 is now bolted on my 350. My t-stat has the big main hose running to the water pump. then it also has 2 oulets on each side of it (4 outlets). 2 lines ran into the front ends of the log manifolds, but now my center rise manifolds have 1 outlet on the bottom near the middle then also an outlet on the top elbow..
I am also converting to thru hull exhaust. I already have 2 4" outlets with internal flappers to install. So i was going to adapt from whatever size the elbows are to the 4" outlets.
So my question is, does it matter what hose outlets on the t-stat go where on the manifolds and elbows?
